+11
Stiko
203 pick up
greaser
kool kruiser
Isabelle
15 participants
Page 14 sur 29
Page 14 sur 29 • 1 ... 8 ... 13, 14, 15 ... 21 ... 29
Re: Chevy 1949 - 1952 customs & mild customs galerie
1949 Chevrolet Fleetline
1949 Fleetline, 235 c.i., 5 spd, stock suspension, but lowered. Runs down the road great, new coil & distributor installed. Split manifolds, dual exhaust, original (but gone through) brakes, driver quality interior. The color is emerald green, it has Dodge Lancer hubcaps, shaved door handles, shaved trunk, frenched headlights, Frenched turn signals, Frenched antenna, dummy spots, one piece Olds windshield, and 59 Caddy taillights. The car also has a new twelve volt harness in it. It was a feature car at Vintage Torquefest in 2013, and been in Good Guys gazette
Matt Slipich's Chevrolet
1952 Chevrolet Fleetline Deluxe 3.5L
Wonderful last year of the Fleetline Fastback that has been pampered over the years. She has the original 6 cylinder which was rebuilt 4 years ago showing 101,500 miles !. Manual 3 On The Tree and Great Mechanical Condition! Starts rights up every time when you want to go to the local cruise-in or car show. Terrific brakes should the local squirrel want to high-5 you...LOL! All gauges functional, horn, a.m. radio and even the clock works !
The interior was refurbished two years ago with new seat covers, door panels and headliner. She was painted this past summer with base clear coat and looks great ! Not concourse quality but you would be proud at any show... The Blue Flames are paint and not decals or wrap. As you see, she has Laker Side Pipes (non functional) and Dual Exhausts in the rear... dummy spotlights as with the era, and Cragar Reverse Wheels with Baby Moons.
1951 Chevy Fleetline Deluxe Mild Custom
This 1951 Chevy Fleetline Deluxe is the perfect So-Cal styled Mild Custom that's show ready and the perfect ride for your local "Cars and Coffee" meet or to just cruise around in. The few times this car has been out it gets a lot of attention and draws a crowd rather quickly. With only your personal finishing touches left the car needs nothing as it sits!
I received this car as a distressed project that was abandoned in the owners garage after the shop he was using ripped him off and skipped town. Many of the new parts were still in boxes, the motor/trans was built and the body work was started. I completed the car by building the custom rear two link, adding detail touches like the trunk sheet metal work and custom rear bumper and handling the paintwork and assembly. I can honestly say every mechanical part on the car is new.
Fresh Professionally Rebuilt 350
-RV Cam
-Offenhauser 360° intake
-Carter AFB 750 CFM Carb
-All Custom Bent Titanium Vacuum Lines
-Sandersons Headers
-Cloth Covered Spark Plug Wires
-Caddy Air Cleaner with Custom Lettering
-Petronix Ign and Coil
-Custom Made Sheet Metal Valve Covers (painted Mist Green)
-Custom Cal Custom Finned Valve Cover (currently installed)
-New Custom Dual Exhaust with Glass Packs have Flow Masters that came with the car if interested
-New Starter, Alternator, Fuel Pump and Water Pump
-New Electric Fan
-Lokar Dip Stick
Fresh Professionally Rebuilt TH350 Trans
-1200 RPM Stall Converter
-New Trans Cooler
-Shift Kit
-New Drive Shaft
-Lokar Dip Stick
Exterior
-New Paint Job in Mist Green
-Custom Painted Trim in Accent Color
-All Trim, Handles and Badges Shaved minus belt line
-Peaked Hood and Rear Fenders
-Westergard style headlights
-1950 Pontiac Rear Tail Lights with Glass Lenses
-Electronic Door Poppers with Remotes
-New Smoked Side Glass and Windshield to include Wipers, Seals and Felts
-All hardware replaced with Stainless Steel Fasteners
-Fender Skirts
-Custom Made Rear Bumper and Brackets
Chassis
-Completely Rebuilt Front Suspension powder coated in Black. All new seals, bearings, tie rods, bushings
-Dropped Spindles and Steering Arms
-New Shocks
-New Brakes and Stainless Steel Lines
-New Fuel Lines
-Custom Built Rear Two Link using Rebuilt '57 Chevy Rear End with Air Bags
-New Viar 350c Compressor, Valves and Tank
-Chassis Painted Black
Additional Features
-Custom Painted Pearl White Dash
-Custom Made Aluminum Dash Pod with AC Tach, Water Temp and Air Pressure Gauges
-New Radial Wide White Wall Tires
-Buick Hub Caps
-Custom Sheet Metal Paneled Trunk
-Completely Rewired front to back, even has new sockets for all the lights
-New front Visor
-RV Cam
-Sandersons Headers
-New Electric Fan
-Lokar Dip Stick
-New Trans Cooler
-Shift Kit
-New Drive Shaft
-Lokar Dip Stick
Exterior
-Fender Skirts
Chassis
-New Shocks
-New Fuel Lines
Additional Features
-Buick Hub Caps
-New front Visor
Mouse over image to zoom KUSTOM-AWARD-WINNER-BAGGED-ACCU-AIR-CUSTOM-LOWRIDER-BOMB-HOT-ROD-RAT-LEAD-SLED KUSTOM-AWARD-WINNER-BAGGED-ACCU-AIR-CUSTOM-LOWRIDER-BOMB-HOT-ROD-RAT-LEAD-SLED KUSTOM-AWARD-WINNER-BAGGED-ACCU-AIR-CUSTOM-LOWRIDER-BOMB-H
BODY/INTERIOR FEATURES
CHOP TOP BY SACRAMENTO KUSTOMS
CHOPPED TOP 5" IN FRONT 7" IN BACK
1950 FORD REAR WINDOW
STRETCHED 1949 CADDY QUARTER PANELS
PACKARD REAR BUMPER
NOSED AND DECKED
ROUNDED HOOD CORNER
SHAVED DOOR HANDLES
1954 PONTIAC FLOATING GRILL
1954 BUICK HEADLIGHTS
DUPONT LEXUS RED
CUSTOM ROLLS & PLEATS INTERIOR BY PACO'S
DRIVE TRAIN/CHASSIS
SMALL BLOCK CHEVY 350 V8
TH350 AUTOMATIC TRANSMISSION
TEN BOLT GM REAREND
TRIANGULATED FOUR LINK REAR SUSPENSION
MUSTANG II INDEPENDENT FRONT SUSPENSION
ACCU-AIR AIR BAG SYSTEM AT ALL FOUR CORNERS
INCLUDES E-LEVEL AUTOMATIC LEVELING AND RIDE HEIGHT MEMORY SETTINGS
This great little car was largely built by Jesse Miller (Sacramento Kustoms/Austin Speed Shop) as his personal car. It was later finished and toured to many shows by Goran Lassell where it took several honors. A high quality driver this car needs This is a perfect car for someone that wants to drive. It has made to trips to Texas, Arizona, Southern Calif and everywhere in between. The car runs, drives, stops, is currently registered with a clear CA title.
Sacramento Autorama Suede Room "Best Kustom" & Gambino Kustoms pick "Best Kustom"
2 awards from Joe Bailon's Blast from the Past
Reno Riot "Best Kustom" 2012 & 2013
"Best Chop" Ink & Iron 2011
"Best of Show" Mala Noche 2012
4 page feature in Traditional Rod & Kulture #30
Good Guys Yearbook 2013 large shot
The car's overall condition is very good but as it is a driver it has imperfections. Please view the numerous photos below and feel free to ask any questions you may have. They say a picture is worth a thousand words so below is over 60,000 words.The car is located at our retail showroom and is available to be seen normal business hours.
» Chevrolet Corvette Customs & mild customs
» Lincoln 1930's - 1948 Customs & mild customs
Page 14 sur 29
