-25%
Nouveaux écouteurs Apple AirPods 2 au meilleur prix
133.90 € 179 €
Le Deal du moment : -29%
Jeu d’ambiance Dobble
7.12 €
1929 Ford Model A Coupe Built by Jason Graham Hot Rods
1929 Ford Model A Coupe Built by Jason Graham Hot Rods Empty 1929 Ford Model A Coupe Built by Jason Graham Hot Rods
Message  Predicta le Ven 14 Sep - 19:24
Exceptional Show Winning Custom built Model A by Jason Graham Hot Rods
GOOD GUYS 2015 Year Yearbook Cover, GOOD GUYS Pros Pick, Beatersville 2015 Top Pick, Wheel Vintiques Catalog Cover & Street Rodder Magazine Street Shaker Award.
Year, Make & Model 1929 Ford Model A 5 Window Coupe, Henry Ford Steel
Engine: 1956 Chrysler 354 Hemi, BDS 6-71 Blower, Crane Roller cam & lifters (492 lift: 288 Adv. Duration), Ross Blower Pistons, Forged H Beam Rods, Dual Holley Ultra Dbl pump 650’s, Mallory Unilite Distributor, O'Brian Polished Aluminum Valve Covers, Custom Built Headers.
1929 Ford Model A Coupe Built by Jason Graham Hot Rods 717
1929 Ford Model A Coupe Built by Jason Graham Hot Rods 218
1929 Ford Model A Coupe Built by Jason Graham Hot Rods 318
600+ HP, professionally built by Peanut – Nashville, TN
Transmission: American Powertrain TKO-600 5 speed, RAM Clutch & Pressure Plate & Hyd Throwout, STRANGE Transmission Yoke & Quick Time Bellhousing
Chassis: Custom Z’d Frame, Split Wishbones, Dropped Straight Axle, Quick Performance 9” Rear with Yukon Nodular Iron Center Section, Billet Steel Yoke, 3.73 Gears, Ford Motorsports Trac Loc Posi unit 31 spline, 4 Link & Rear Air Ride w/ wireless controller, 11 in Ford Rear Drum Brake and SO-CAL Speed Shop Hot Rod Front Disc Brakes polished.
Body & Paint: Chopped 7” Front…6 Rear, 316 Louvers, ‘32 Headlights, ‘50 Pontiac Tails, “Satin Copper Pearl” Dupont Custom Mixed Paint, Striping by Rick Harris. Body has Satin finish, wheels, frame and engine are contrasted with gloss finish.
Interior & Audio: Modified ‘55 Chevy Dash, Classic Instruments BelEra Cluster with Sky Drive GPS speedo, Two Tone Maroon & Black Diamond pleated interior by Jason Graham, CON2R Steering Wheel
Tires & Wheels: Wheel Vintiques Steelies, Coker Classic Wide Whites: (R) 7.50R16, (F) 5.50R16
1929 Ford Model A Coupe Built by Jason Graham Hot Rods Empty Re: 1929 Ford Model A Coupe Built by Jason Graham Hot Rods
Message  Predicta le Ven 14 Sep - 19:25
1929 Ford Model A Coupe Built by Jason Graham Hot Rods 618
1929 Ford Model A Coupe Built by Jason Graham Hot Rods 519
1929 Ford Model A Coupe Built by Jason Graham Hot Rods 419
